Somethings up in the front end....
So I happened to have just made and appointment for an oil change and a safety sticker. I was backing up to leave work today and cut the wheel hard to the right in reverse and got this loud clacking/snapping noise out of the passenger side front. You could feel it in the floor boards. That and a sort of low squeek noise. Sort of rubber on rubber noise. Then while driving at slow speed I got this noise that sort of sounded like the ABS noise when you get on the brakes hard, or maybe the cylinder cutout noise? But not over 35-40mph. Then....everything just stopped making noises. Didn't happen again all the way home 89 miles. Even tried to do the noise backing into my driveway. So tomorrow I am going to have them check the 4 wheel drive and front universals/hubs etc....Make sure they do a chassis lube on it to.
Just got back from the stealership. Bad wheel bearing on the right side front.
They brought me back into the bay and there was quite a bit of play and was making a grating sound. Probably good I went in seeing as I was just doing 80 on the highway the day before.....
The damage.....$495.00 for a sticker, oil change and a front hub.
yea i just had similar situation plus a constantant whining/grinding sound... left front wheel bearing burned up. I had about 72,000 on mine how long did yours last?
only thing im noticing now is when i turn the wheel hard to the left to back into driveway i swear i keep hearing a weird clicking noise for about rotation... then it goes away. hopefully they put the bearing in right?
I'm about to put slotted/drilled rotors and new pads on my truck (just under 60k) and while I'm at it I am going to do my bearings since it seems people see them going bad around 70k...anyone else having bearing issues?
RAMULAK, how many miles do you have on your rig?
Trending Topics
I had a nasty sqeal when i would turn the wheel lock to lock, turned out it was the sealed lower ball joint ran out of lube, dealer replaced both lower control arms, 100$, you gotta love that lifetime bumper to bumper max care.....btw, i miss the days of zerk fittings.........
