Headlight Ground Wire - 2009 Dodge Ram
Old Aug 20, 2014 | 01:34 PM
kelvinmasur's Avatar
kelvinmasur
New Member
Default Headlight Ground Wire - 2009 Dodge Ram
Long story short I screwed something up and need direction. While messing with the three headlight wires, I somehow screwed up the center ground wire. The only way I can get my headlights to work is to make a new ground wire attached to the metal. The wires are not loose around the connection.
The ground wire that runs into the vehicle's wireing harness is not grounding. I didnt pull on the wire, not sure why that ground wire is not working. Any ideas on what I broke in regards to this ground wire not working?
2009 Dodge Ram 1500
Old Aug 20, 2014 | 02:09 PM
Moving to the correct section. One post on the issue is plenty.
Old Aug 1, 2021 | 06:53 PM
J D GA's Avatar
J D GA
Default If it was moved, how did it show up where it wasn't supposed to be?
This is another post that admin moved but didn't provide a link to where it was moved to. That doesn't help me find the thread. Can't you move it and then provide link to where it is now? Better yet, if it was moved, how did it show up where it wasn't supposed to be?
Old Aug 1, 2021 | 07:49 PM
Usually, there will be a notice sent that it was moved, and also a link to the new location from where it was moved from. Of course, the notice is sent to the original poster..... Not anyone else.
