4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Anyone had issues with the trans lines going bad? Just had an oil change and they said that the trans lines have a minor leak. I had to get them replaced at around 90-100K miles? (I'll have to check my receipts) because they were rotting out - seems like at 112K it might be happening again.
brr, too cold for me - I'm a wimp. I'm guessing that since they found the leak from the bottom, it at the trans itself. Probably just from the previous installation. Good luck and hopefully it's still under warranty.
I had to have mine replace too ... after I was accused of putting some stop leak or some crap in my tranny (I did not put anything in!). My tranny temp was running high when towing, shop said one of the lines also had a crimp in it. Anyway, had it replaced ... so far no other drama with it.
Finally crawled around under there and it looks like the majority of the leak is coming from the pan gasket. Ordered up a new filter/gasket kit and I'll fix that first and then see if anything is actually leaking from the lines - I didn't see anything.
