Push Pin Tool.
Well I decided to take a look myself at the windshield washer tank/hose to see where the river is coming from.
The felt material that surrounds the top of the engine compartment is attached with push pins. I must remove at least one to clear the tank.
Since I do not want to destroy the pins, I looked and I and see they make a tool for this. Don't get it. Looks like any thing to pry it up would work the same.
How does the tool get behind/under the top of the pin and squeeze the pin together for removal?
Or should I just pull them off and get new pins?
I rarely touch anything like this, but cash is king today and I'm trying to keep as much as I can.
Are you talking about the kind where the center comes out first then the entire pin pulls out? If so, go buy a trim removal tool set from Harbor Freight, they are designed to remove pins like this.
They are all along the interior edges of the engine compartment. Black plastic push pins holding the felt like material.
I have looked at the tools and my question was "how does this tool squeeze the pin to allow removal"?
The tool just looks like its for prying.
I will check the "set" as the tools i have seen are not removal sets. Its a single tool for prying.
I just use a flat blade screwdriver to get uner the edge to start it, then a pair of large wire cutters to get under both sides and pry it out.
These work better, but I like to Mcgyver things.
http://www.harborfreight.com/6-piece...set-66188.html
That set will work fine, I've just never liked to use anything metal when prying parts off a car, this is the one I have and would hate not having it.
http://www.harborfreight.com/5-piece...set-67021.html
Agreed. I have the same set in my toolbox. Plastic doesn't scratch. If it is just a plain one-piece head, slide the fork under and pry it up. If the head is two pieces, a wide washer looking part, then a smaller flat top version in the center, pry the smaller one up then pull them both out together.
