Need OBD For 4.7
Sep 20, 2015 | 07:49 PM
Need OBD For 4.7
Whats the best one for my 4.7? What I need is one I can buy to read the codes any suggestion's?
Reason: No enough Info
Sep 21, 2015 | 08:04 AM
Best one what? All vehicles have OBD. Your vehicle is OBDII, so what are you asking? Please be more specific.
Sep 22, 2015 | 01:40 PM
I want to buy one to read my codes not the on board one. I want the best.
Sep 22, 2015 | 01:49 PM
Quote:
Originally Posted by
Ticktock09
Well then, if you want the best, get the one the dealer uses:
http://www.newegg.com/Product/Produc...B&gclsrc=aw.ds
And the good news - at this vendor it's discounted 25%!!!
Sep 22, 2015 | 01:51 PM
So you just want a code scanner? Actron makes some good stuff.
Sep 22, 2015 | 01:54 PM
No 'Keats, HE WANTS THE BEST!!!
Sep 22, 2015 | 02:02 PM
HammerZ71
I don't need that just an after market one will do. 10,000 $ is too much.
Sep 22, 2015 | 02:05 PM
If you want to keep it under $10,000, here are a few options.
- Will read and clear only basic fault codes.
- An advanced code reader, reads and clears code, including ABS & SRS codes.
Or, get a programmer for your truck, which also will read and clear codes.
Sep 22, 2015 | 02:33 PM
My bad, could have sworn you indicated you wanted the best.
Get a programmer, for the $300 or so you'll get a full blown scanner AND all the power, transmission and MPG advantages of tuning your PCM/TCM.
If not then go get you a basic $20 Autel and just throw it in the glove box...
