Door Hinge Lubrication
Old Feb 6, 2016 | 08:17 PM
bluebeast1562's Avatar
bluebeast1562
Default Door Hinge Lubrication
Ok guys, as the title suggests, looking for some info on lubing the door hinges. I have lubed them in past but the lube makes one heck of a mess, any suggestions on lube type or tips/tricks to it?
Thanks
Old Feb 6, 2016 | 08:20 PM
primem's Avatar
primem
for doors that already squeak, penetrating fluid works well.
Old Feb 6, 2016 | 09:36 PM
Duso02's Avatar
Duso02
Penetrating lube to clean them, then use white lithium grease to lubricate them.
Old Feb 6, 2016 | 11:49 PM
chevelle68's Avatar
chevelle68
We had the dealer check it out during a routine visit and it appears they put on the white lithium grease. Not a lot, did not look too messy, and it did take care of the issue.
Old Feb 7, 2016 | 09:48 AM
Sniper_Merc's Avatar
Sniper_Merc
WD40 makes a spray type white lithium grease that can actually get into the door hinge a bit better, might be worth a shot.
Old Feb 8, 2016 | 07:40 AM
oldjeep's Avatar
oldjeep
I use a white spray lithium that drys to a powder. Spray the crap out of them a couple times a year. Most of the noise comes from the roller that holds the door open, not the hinges.
Old Mar 10, 2016 | 02:00 AM
duke07's Avatar
duke07
I like using Wurth HHS-2000. Sprays on thin so it can creep into tight spaces yet leaves little or no mess.
Old Mar 10, 2016 | 12:01 PM
706jim's Avatar
706jim
My door hinges started squeaking very early into the truck's life. I gave them a squirt of WD40 and they've been good ever since. Personally, I don't think WD40 would be the best choice, but in this case, it worked. Haven't reapplied it for at least three years, so there you go.
