TPMS light won't go off
I just traded my 2011 Ram Bighorn in for a 2016 Ram Rebel. After driving for half hour or so the TPMS light came on, flashing at first and then solid. I checked all the tire pressures and they are good. Is there anything else I can try, and can I reset this light from home without any special tool?
Here's what I found on page 309 of the Owner's Manual, T Man:
"Your vehicle has also been equipped with a TPMS
malfunction indicator to indicate when the system is not
operating properly. The TPMS malfunction indicator is
combined with the low tire pressure telltale. When the
system detects a malfunction, the telltale will flash for
approximately one minute and then remain continuously
illuminated. This sequence will continue upon subsequent
vehicle start-ups as long as the malfunction exists.
When the malfunction indicator is illuminated, the system
may not be able to detect or signal low tire pressure
as intended. TPMS malfunctions may occur for a variety
of reasons, including the installation of replacement or
alternate tires or wheels on the vehicle that prevent the
TPMS from functioning properly. Always check the
TPMS malfunction telltale after replacing one or more
tires or wheels on your vehicle, to ensure that the
replacement or alternate tires and wheels allow the TPMS
to continue to function properly."
So, if the issue is with a tire, the light should come on solid and you should receive a message in the EVIC. If the issue is with the TPMS system, it will behave as stated above.
