Notices
lots of dodge ram parts
Old Oct 3, 2006 | 03:00 AM
robert97dodge's Avatar
robert97dodge
Default lots of dodge ram parts
Gas tank 94-01 dodge ram $50
Balance rings that slip on the wheel studs before the wheels goes on. They are a 5X5.5 bolt pattern. $75.
Transmission pan fits 94-01 dodge 46 trannys. $25
Oil pan Dodge magnum 318-360 motors $30
air intake tube that goes from fender to stock air box $10
compressor and altenator bracket that mounts on the top front of magnum motors $25
throttle body with all sensor and linkage bracket $45 fit magnum motors
left and right D44 dual piston calipers will fit 00-01 D44's. $20 Each
CAD collar that slides back and forth to connect axle shafts from a '01 D44 $10
2- distributors from a magnum 318 motor $20 each
fuel rails and injectors from a 97' magnum 318 $40
D44 and chrysler 9.25 stock covers $25 each
D44 yoke $20
2- 8 lug spare tires wheels $20 each
1- 5 lug spare tire wheel $20
'01 chrysler 9.25 with chewed up 4:56 gears in it. $125 complete axle with drum brakes and axle shafts.
Motor mounts for 94-01 magnum motors $20
'01 Dodge D60 4:10 ring pinion and carrier $75
16X8 chrome mods wheels. 8X6.5" bolt pattern. Brand new stilll in the box $200
4 chrome dodge ram plastic center caps $20
318 magnum flex plate $20
Used rear driveshaft u-joint for trail spare NAPA part #316 $10 shipped
2 kicker 12" round sub grilles $30 for both paid $25 each
Transmission dipstick and tube that dipstick goes in $25 from a '97 tranny
2 pioneer 6X9's $40
3" dodge ram coil spacers $70
DOM tubing, threaded inserts, jamb nuts, and one TRE for chevy one ton steering conversion on a dodge ram $120
2- D44 '00-'01 disk rotors $20 each
Old Oct 10, 2006 | 01:22 AM
robert97dodge
Default RE: lots of dodge ram parts
TTT
Old Oct 10, 2006 | 02:05 AM
dsertdog56's Avatar
dsertdog56
Robert, I know I asked you this in P.S.com. but I have some new information. I'm told the 97 and up linkage is the same on the throttle body. Yours should have the tang on the out side for the foot feed, and a plastic guide on the inside for the kickdown cable(?) It looks like a teardrop. If thats it, and there's no corrosion. I'll take it. thanks.
If its a early 96 and older the linkage is different. Hughes engines shows a picture of all three on thier web site.
Old Oct 10, 2006 | 03:09 AM
robert97dodge
ORIGINAL: dsertdog56
This throttle body is off of a '97. It is the same thing that is on my '01.
Old Oct 11, 2006 | 01:21 AM
Mike99ram's Avatar
Mike99ram
will those rotors fit a 99 1500 with a 3.9?
Old Oct 11, 2006 | 02:07 AM
robert97dodge
ORIGINAL: Mike99ram
No they will only fit 00-01 1500 4x4.
Old Oct 11, 2006 | 02:45 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
pm sent
Old Oct 11, 2006 | 10:40 PM
dsertdog56's Avatar
dsertdog56
I'll take the throttle body! How do you want payment? Paypal? Money order? E mail me @ dsertdog56@hotmail.com Thanks!
Old Oct 15, 2006 | 06:38 AM
JarheadX's Avatar
JarheadX
16X8 chrome mods wheels. Brand new stilll in the box $200
got pics?
Old Oct 16, 2006 | 04:06 AM
robert97dodge
They are 8 lug wheeels and I dont have pics right now.
ORIGINAL: JarheadX
got pics?
