Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
Java Help...
Old Oct 24, 2007 | 06:00 PM
Natedogg625's Avatar
Natedogg625
Default Java Help...
Hey is there any one here that can help me out with java programming??
I need to get 1 ball to appear in 1 random spot on my screen each time I run it.
I have it set up now, but my ball is always moving to a random spot.
any help would be great
Old Oct 24, 2007 | 06:25 PM
cpukramer's Avatar
cpukramer
Default RE: Java Help...
zip up the source file and email it to me. I can take a look for you. sounds like a loop problem. I should be able to figure it out for you.
Old Oct 24, 2007 | 11:01 PM
cpukramer's Avatar
cpukramer
alright man I downloaded your source code and looked it over. Unfortunately its a little hard to troubleshoot without the libraries or a compiler. I have the compiler at work and assuming its a standard library I should have that too. Unfortunately I'm on the road until Saturday, so I may not be able to help you much more until then. I'm not sure when the assignment is due, but hopefully someone else on here has more Java experience than I do. I am more of a C++ guy (which is really similar to Java in a lot of instances except for maybe this one with animation and such, lol). keep me posted though! I will certainlly try to help you more once I get back.
Old Oct 26, 2007 | 01:24 AM
Natedogg625
Well the assignment is due today (fri). and I have 99 percent of the code done. The only thing I need to do is figure out my clickListener so when I click on my red circle it stops for a period of time. If I cant figure it out, its only 5 pts out of my grade.
Old Oct 26, 2007 | 06:11 AM
pghsebring's Avatar
pghsebring
I don't have the files, i can't look at it. doubt you're up right now. You should have posted the code.
Old Oct 27, 2007 | 05:07 AM
Natedogg625
never really thought of that one... but I already submitted the program.
