Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
FLASH.ocx problem
Old Nov 2, 2007 | 04:45 PM
Dakota_24's Avatar
Dakota_24
Default FLASH.ocx problem
I recently have been getting a FLASH.ocx error on my laptop ever so often. It's really bugging me. Does anyone know what it is and if there is any free software on the net or whatever to take care of it?
Old Nov 3, 2007 | 10:56 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: FLASH.ocx problem
I found this for you, hipe it helps.
Apparently there are some third-party screen savers out there that use Macromedia's Flash Player to render the images when the screen saver kicks in. A third-party screen saver is something that you installed yourself and should not be confused with the built in screen saver that is part of your computer's operating system. These screen savers are coded to look for the file flash.ocx and recent version of Macromedia's Flash application now name the same file flash9.ocx or even flash9a.ocx. The reason you get this error message is that the screen saver is looking for the old file name. Personally, I don't really care for third-party screen savers. I find them to be problematic and sometimes even detrimental the efficiency of a computer. I just use the built in screen saver to protect my display. To fix this problem, you have two options. The first one would be to simply uninstall the screen saver. Once that is done the error will go away. The second option is for those of you who simply cannot bear to part with your screen saver and is a bit more involved. What you will need to do is find the flash9.ocx file and copy it as flash.ocx. To do this, browse to the C:\Windows\System32\Macromed\Flash folder. Locate the flash9.ocx file and right click it and select copy. Now just right click in a blank spot of the same folder and select paste. You will then find you have a file called Copy of Flash9.ocx in the folder. Right click the new file and select rename and change the name to flash.ocx. Once complete, the error should be history.
If this doesn't work, google flash.ocx and there are fixes on the net.
Old Nov 3, 2007 | 03:39 PM
Dakota_24's Avatar
Dakota_24
Thanks for your help. I fixed it last night. I took it over to a friends house and he helped me figure it out. We looked it up also and a light bulb clicked in my head that my screensaver hadn't come up in a few days. So then we followed the instructions and ...TA DA!!!!!!
