Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
rwal sensor
Old Aug 26, 2008 | 08:05 AM
sjacks's Avatar
sjacks
Default rwal sensor
the abs brake light popped up on my dash.I thought it might be the sensor on the differential,I replaced it but the abs brake code still comes on.Is there a drivability cycle that has to take place before the code is erased from the pcm memory.Thanks,steve
Old Aug 26, 2008 | 09:46 PM
dhvaughan's Avatar
dhvaughan
i don't know. but on my 01 ram, the pcm can be reset by disconnected the negative battery cable and turning the ignition to start for 30 seconds.
