Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
what happened?
Old Feb 17, 2009 | 10:29 PM
matthewbeard's Avatar
matthewbeard
Originally Posted by Altair
Sounds like you will need a reformat. Did you already get the pictures and what you wanted off it? If not and you have access to a computer that can burn CD's you can probably get your files off by downloading Knoppix and burning it to CD then using that to get your files (It runs off the CD). This will be easiest if you have a USB Flash Drive or External USB Hard Drive you can save the files to.
Knoppix can be downloaded here: http://www.knoppix.net/
A tutorial for using it is here (this was written with an older version so the pictures may look slightly different but it is done the same way): http://www.shockfamily.net/cedric/knoppix/
Good Luck!
Don't need to reformat, install a new copy of windows right overtop of the old copy
