Dodge Forum Site Issues and Suggestions Having an issue with the DF software? This is your section!
1500 Ram Van 3.9 Running Hot
Old Jul 2, 2014 | 12:26 PM
kwdnjd's Avatar
kwdnjd
Default 1500 Ram Van 3.9 Running Hot
After blowing a T connector I started looking for "why". I dismissed the water pump (replaced last year). I did find the radiator was restricted. Cleaned and flushed it as well as h-core, changed hoses, thermostat and r-cap. But still running hotter than normal. After driving for about 45 minutes it got hot enough that I had to run heater to keep from overheating. Put sealer in fluid by chance there was a head gasket leak. Checked oil and fluids and did not find any evidence of a gasket leak. However, I did find that when the engine would get hot...that if I stopped, ran the heater, and increased engine rpms that the temp would come down.
?1. could I have a gasket leak and not notice it.
?2. based on the rpm mentioned above, could the w-pump need to be replaced (when I first start the engine I hear a squeek like a dry pulley).
I would really appreciate some advice.
Best regards,
Old Jul 2, 2014 | 02:01 PM
Welcome to DF. Please take a few minutes and read the section descriptions so you post in the correct area. This section is for reporting issues with the Dodge Forum internet site, not vehicle specific sections. From the main form page, scroll until you find the Ram Van section and post in the appropriate generation section for your vehicle.
