Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Swapping Autostick
Old Nov 9, 2007 | 06:09 PM
Bigredva's Avatar
Bigredva
Default Swapping Autostick
Hi everyone. I have a 2000 Intrepid ES with the 2.7 and autostick, and I just bought a 2004 Trep ES with the 3.5. I was wondering if it's possible to move the autostick to the new car. If so, what would I need to change and such?
Thanks!
Old Nov 9, 2007 | 06:31 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: Swapping Autostick
how much money do u want to spend??? look around 1300 just to startt for parts
Old Nov 10, 2007 | 10:02 AM
Bigredva's Avatar
Bigredva
I'm not quite as concerned with the cost yet.I'd just like to know if it can be done, and what I'd need to do it.
Old May 11, 2008 | 02:12 PM
cokey11's Avatar
cokey11
The 04 autostick system is different than previous years and you do not require an autostick enabled TCM. In 04 the TCM is built into the PCM, therefore all you require is the autostick shifter with the harness, and an autostick capable speedo cluster. If for aestetic reasons you want the autosick bezel, you can get one of those too, but if you have the leather shifter bezel, there is adequate side-to-side movement. I recently did this install for about $120.00,although could have done it for $80, but I wanted the bezel,and a Concorde cluster ( required me to buy a Concorde and Intrepid clusters and change faces, as the Concorde did not come with autostick )
