Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
2001 Intrepid with DTC P0432
Old May 7, 2008 | 09:27 PM
Gnurl's Avatar
Gnurl
Default 2001 Intrepid with DTC P0432
Engine light came on and I checked the codes, it was P0432, "Main Catalyst Efficiency Below Threshold (Bank 2)"
I could find no info on this except for a Durango on this forum, actually. Does this have 2 catalytic converters, or just 1 (and what would Bank 2 mean in that case)? And is it true they must warranty it? I have 160k+ miles. I loathe the idea of going to either of the 2 nearby dealerships. One of them charged me $800 fixing things once before they figured out it was an O2 sensor that needed replacing (and leaving a pressure guage attached to one of the cylinders at that, when returning it to me.) I should've kept it and sold it on eBay.
Old May 8, 2008 | 10:13 AM
kurts2's Avatar
kurts2
Default RE: 2001 Intrepid with DTC P0432
The exhaust system consists of two front close coupled catalytic converters. Both converters attach directly to the exhaust manifold using a V-Band clamp. Normally bank 1 is right, bank 2 is left, check with an auto parts store, they can confirm.
Good luck,
Kurt
