Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
2.7 to 3.2 Swap--No Start--Need Help!
Old May 14, 2008 | 05:59 PM
race21's Avatar
race21
Default 2.7 to 3.2 Swap--No Start--Need Help!
We just completed our second 2.7 to 3.2/3.5 swap. This swap was to a 3.2 in a 2000 Concorde. We went to start it today and we have nothing. When you turn the key, the check engine light icon doesn't light up in the dash, so I don't think the pcm is getting power for some reason. The pcm isn't telling th starter relay to engage the starter. I have power going to the starter and the distribution box for the fuses and relays from the battery. I even checked for power at the box and it is present there. When I turn the key I do have some lights in the dash, seatbelt light and some others that aren't pcm related I guess. I'm wondering if there ispcm ground or something. I have very generic wiring diagrams that are not very detailed. Which wires or pins does the pcm receive power? Do you have any ideas? I did the swap the same way we did thefirst swap which was a 3.5 into a 2002 Intrepid and didn't have any problems with that.Thanks for any help!
-Jason
Old May 14, 2008 | 10:08 PM
Black Hawk's Avatar
Black Hawk
Default RE: 2.7 to 3.2 Swap--No Start--Need Help!
If the new engine is from like a 2002 or newer, it's not directly compatible.
Old May 15, 2008 | 09:05 AM
race21's Avatar
race21
The motor isfrom a 2000 Concorde also.
