Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Coolant leak from under the engine!!!
Old Mar 31, 2009 | 10:04 AM
mistergabe's Avatar
mistergabe
Default Coolant leak from under the engine!!!
i have been experiencig overheatting within a very short time period of driving, i mean with ina few miles. come to find out that i am losing antifreeze, at one point my car locked up and ahut off, and rested for a bit and then i drove it home. once i took it to a mechanic, he thought that i had cracked my engine block because after doing a pressure test the fluid just drizzled all out from the middle of the front end. hard to see where from. then i took ait to a dodge dealer and they told me that it was a leak in a tube that goes straight down the middle part of my engine that has a crack in it. what is this tube called? what can i do to fix this issue without coming out of too much money? thanks
