Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
1999 3.2 intrepid
Old Oct 14, 2009 | 04:59 PM
jasperwk's Avatar
jasperwk
Unhappy 1999 3.2 intrepid
the car starts hard and has an idle at about 1800rpm i hooked up the scanner and checked the iac and it showed 0 i tested the operation and it seemed to work as it would let me raise the rpm and bring it back down but not below 1800 rpm i disconnected the iac and sprayed carb clean and couldnt find any vac leaks the only code stored was idle speed not achieve +- 100rpm any ideas???????????
Old Oct 14, 2009 | 07:02 PM
shelbydaytona's Avatar
shelbydaytona
iac @ 0 and high idle. absolutely a vacuum leak and a big one
Old Oct 15, 2009 | 09:37 AM
jasperwk's Avatar
jasperwk
Unhappy 1999 intrepid high idle
when i block off the iac port in the throttle body the idle comes down to 700rpm and idles smooth and steady
Old Oct 15, 2009 | 11:34 AM
shelbydaytona
verify the iac is able to move if u have a good scanner u should be able to move it thru the functional tests
Old Oct 15, 2009 | 12:18 PM
jasperwk's Avatar
jasperwk
Just a little history on myself i'm ase cert and have been wrenchn 18 yrs so i know what your saying i was able to move it with my snap on solus but it wouldnd let me slow it down past 1700-1800 rpm i replaced the iac and it idles normal now must have a bad spot in the old iac thanks for the help jasperwk
