Passenger side inner tripod joint stuck
i have a 1996 dodge intrepid 3.3 liter and i got my entire axle assembly off but the inner tripod joint. i pryed it endlessly and even put a pully to a tree and cranked it and the entire car moved. This tripod joint is really in STUCK! It will not come out. Do i have to put my car in a certain gear? I know there is a way to take this out, but I need some assistance. any help is much appreciated. thank you. michael
you can't pull, you have to 'SNAP' it out. I use a long pry bar and give it a quick sharp yank to snap it off. if that doesn't work, then I use a shorter pry bar and a BFH (big hammer) and whack the bar to dislodge the inner joint.
I use a brass punch and hamer right on the lip (on the shaft not the body of the tripod joint). There is a snap ring in there that needs to be compressed into a indented slit, then the splines slide right out. It can be tricky sometimes.
i actually tied a chain around it, and tied a pully to a tree and crank it. the car moved! the damn tripod wont come out. i will try banging it or something like ya guys suggest.
I don't bang on it, I use a pry bar and give it a quick snap. you can pull on these shafts with a come-a-long and they won't come off, they need a jarring snap not a steady pull. but then if you still can't get it off, then more extreme measures will be needed. I had to use a 10lb slide hammer and heat the thing with a torch to get one off that was really rusted on.
