Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Second generation intrepid transmission limp mode solved
Old Mar 15, 2020 | 12:51 AM
Ray Huggins's Avatar
Ray Huggins
Default Second generation intrepid transmission limp mode solved
Was going through the well-known limp mode change speed sensors would work for a minute and then screw up again finally changed the fluid and haven't had a problem in over a month when I did change the fluid it would didn't smell burnt it didn't look bad I didn't think it was going to work at all because the fluid looks really really good but it wasn't it was broke down and no good filled it up with New + 4 and it's been happy ever since and so am I
Old Apr 9, 2020 | 10:33 AM
khnitz's Avatar
khnitz
Hi Ray, just to follow up after a few weeks - has your transmission still been working OK? I have P0700 and P1776 trouble codes, and the transmission would shift fine for 1-2-3, but sometimes when trying to go into 4 it would fail and revert to limp-mode and stay in 2nd until the next ignition cycle.
I currently have the transmission oil pan off and am preparing to drop the valve body with the attached solenoid pack (its a 2003 Intrepid). The fluid was very smelly, and there was a bit of sludge/particles in the pan (the magnet had a good layer of particles stuck to it. The Intrepid has ~79k miles, and I don't think the fluid was ever changed.
Thanks for your feedback.
