Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
1994 Dodge intrepid OBD 1 code reader
Old Nov 18, 2022 | 07:40 PM
Smarhail's Avatar
Smarhail
Default 1994 Dodge intrepid OBD 1 code reader
The good ol 1994 is acting up yet I can't find the proper code reader. Anyone have any ideas where I need to look?
Old Nov 18, 2022 | 08:52 PM
To obtain fault codes using the MIL (Check Engine Light):
1. Cycle ignition key to ON, OFF, ON, OFF, ON within 5 second (do not actually crank engine!!)
2. Count the number of times the MIL on the instrument panel flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses seperate the individual two digit trouble code.
Example: Lamp flashes 4 times, pauses, then flashes 6 more times. This is an indicates a DTC of 46.
3. Lamp will always flash 55 at the end of the test. This signals the end of the test
Old Nov 20, 2022 | 06:54 PM
ol' grouch's Avatar
ol' grouch
You have one built in your dash. It's your check engine light. Like Jkeaton said, do the key dance and count the flashes. Be sure to have a notepad and pen or pencil handy. You will quite likely get code 12. That mans the battery has been unhooked in the last 50 to 100 key starts.
