Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Transmission, Dash Gauges
Old May 27, 2006 | 03:31 AM
tdecsr's Avatar
tdecsr
Default Transmission, Dash Gauges
I recently had a (seemed to be) minor accident and the my car was towed.
Besides my headlight brackets everything looked fine.
At he impound lot though my power steering pulley was on the ground in 3 peices along with the serpentine belt. I replaced the pump and at first things were fine but now my dashboard needles won't move, except RPM and gas going in and out.
The transmission gear lights dont move, stay on, and the transmission doesn't shift gears. Because of the dash problem I'm hoping it's not the transmission and someone can help me figure out what.
Also before the accident my headlights would only come on using brights which was not bright--It suddenly started working on its own (i think) but the REGULAR-BRIGHT difference still isnt much.
Old Oct 18, 2007 | 08:57 PM
swift222's Avatar
swift222
Default RE: Transmission, Dash Gauges
Your PCM is in the passenger side frame rail below your airbox, check and make sure this wasnt damaged in the accident a shock like that could have done something to it Just an Idea.
