HELP NO BRAKES! STRANDED!!!
Hey,
2001 Dodge Intrepid: OK,no brake lights,and it feels as if their are no power brakes,whats up? Besides checking all the fuses whats next? Are these brakes electronic or all vaccum assist? jtcfanof3@hotmail dot com Thanks |
RE: HELP NO BRAKES! STRANDED!!!
fuses would be for ABS u dont use abs unless u are out of control.
base brakes are vas assist look for the big hose to be off near the vac booster ifs its good then u ahve a master cly issue or a vac assist issue |
ABS is not only on during those conditions,its always active,thats why if you have an ABS issuie,the ABS light comes on regardless of out of control or not.
Anyway,it acts like it has no vacum even with the engine on,but its still does not explain the lack of brake lights at the same time? It acts as if the engine is not on,I suppose replace the VBB and go from there,if I hook up a Vacum gauge too that line and see how much vacum it has how much should I have on this car? |
ORIGINAL: jtcfanof3 Hey, 2001 Dodge Intrepid: OK,no brake lights,and it feels as if their are no power brakes,whats up? Besides checking all the fuses whats next? Are these brakes electronic or all vaccum assist? jtcfanof3@hotmail dot com Thanks |
i KNOW THE DODGE VANS SOME COME EQUIPED WITH A POWER ASSIST MOTOR LOCATED UNDER THE LEFT ENGINE BANK THEY TEND TO HANG UP FROM SLUDGE. .
