Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
dodge journey 4 cyl starter
Old Aug 21, 2013 | 04:06 PM
jacobabernathy's Avatar
jacobabernathy
Default dodge journey 4 cyl starter
trouble locating the starter on this vehicle. I've had the same intermittent no-start issues that I've read about all over the web. can someone help me locate the starter so I can change it out?
Old Aug 22, 2013 | 04:04 PM
DodgeCares's Avatar
DodgeCares
Attachment 21331
Attachment 21332
Attachment 21333from the 2013 (not sure which year you wanted) JC 2.4L FSM-
2.4L
See first picture -
1. Disconnect and isolate the negative battery cable.
2. Remove throttle body.
3. Remove starter mounting bolts (1) and negative battery cable (2) from transmission housing (3).
4. Remove starter motor (4) from transmission housing (3).
See second picture -
5. Position starter to move past the intake manifold.
See third picture -
6. Remove battery cable nut (5), ignition sense wire (4) and battery cable (1) from solenoid stud.
7. Disconnect electrical connector (3) from starter solenoid (2).
8. Remove starter from vehicle.
NOTE: APPARENTLY I DO NOT HAVE THE CAPABLITY TO ADD PICTURES/DRAWINGS (attachments.) I apologize if the directions without the pictures are confusing.
