Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Rear wiper motor
Old Mar 15, 2014 | 07:31 PM
jayman920's Avatar
jayman920
Default Rear wiper motor
I'm trying to replace my rear wiper motor, can anyone help me how to remove the back cover and access the motor.
I appreciate any help getting tired of pulling into the gas station to clean the window lol
Old Mar 15, 2014 | 08:49 PM
bigtsr's Avatar
bigtsr
Have you tried to reset the TIPM yet?
There are several screws inside the hatch to remove
then with a little muscle to release it from the pop
clips around the cover perimeter it will come off.
Old Mar 16, 2014 | 07:39 AM
jayman920's Avatar
jayman920
Thanks for the reply, what and how do i reset the TIPM?
Thanks Jay
Old Mar 16, 2014 | 09:37 PM
bigtsr's Avatar
bigtsr
TIPM reset is done by disconnecting Negative battery
cable for 10-15 minutes then re-installing , reboots
electrical bus system.
Old Apr 10, 2014 | 12:32 AM
Ppcdc30's Avatar
Ppcdc30
I have a 2009 Dodge Journey SXT AWD and I have started to have a problem with the rear wiper. When. It operates on the intermittent setting it just continues to run without pausing and when you turn it off it stops where it is on the window without going back to the home/stored position. The washer fluid function works fine also. I have tried disconnecting the battery to resolve it and did not help. When you turn the switch on the column on you can hear a relay switch on under the hood in the fuse box. I cannot locate which relay it is because they did not mark them for some reason.
Has anyone had this problem before or able to help me in directing me in a direction to fix or possibility of which relay that controls this so I can isolate it without taking it to a dealer to put it on a computer to see what the issue is.
Old Mar 25, 2020 | 04:13 PM
icejester's Avatar
icejester
Default broken wires
i removed the wire boot at the top left of the hatch door..5 wires were broken in half from wear and tear over time..spliced them back together..all works again
Old Jul 21, 2020 | 09:15 AM
Hatem Megaly's Avatar
Hatem Megaly
Anyone have the pin assignment fir the rear motor connector please?
