Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
help 2010 journey
Old Feb 15, 2015 | 10:40 PM
Townie's Avatar
Townie
Exclamation help 2010 journey
hi i have question for you maybe you can help dealer here in canada don't know **** i have a 2010 journey and this is what is on. on my dash first the esp/bas light is on and the airbag light is on and the other day i was driving took a turn and my horn started to honk and then it would not stop took out fuses from under hood to stop it and put them back in after and now horn dont work at all. also even with esp/bas lights on i still have traction control and abs and cruise conrtol what might it be thanks
Old Feb 16, 2015 | 08:17 AM
bigtsr's Avatar
bigtsr
First thing you may want to try is to disconnect the battery
at the negative jumper connection for 10 - 15 minutes , this
reboots the TIPM (Computer) which controls all these items.
If this fails the main suspects would be the TIPM and its harness
connections ,a broken or shorted wire in the loom from cabin to
engine compartment and in the case of the horn or any component
operated from the steering wheel the clockspring.
