Shifting/high engine rev help please
Hi, I have a problem with my wifes 2010 Journey. It will rev really high (4-5k) but not feel engaged then if I let off the gas it will go down to 2-25k and then I give it more it will go back up to 4-5k. I can get it up to 55mph at best. Ran the cel's and there were 6 total. Some I'm thinking have nothing to do with this problem.
1) P0571 Brake switch
2)P076A Shift solenoid (thinking this one makes the most sense)
3)P0406 Egr position sensor
4)C0077 Tire pressure ??
5)C1000 Brake pedal switch
6)C107C Another brake switch code
Any help is appreciated. Thank you
edit- 120000 on the odo
We have the same issue with my wife's as well, the dealership could only find an issue or codes for the oil control valves....would those effect that issue?
