Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Replaced battery, remote start no longer works
Old Dec 16, 2016 | 08:09 AM
Rick Fahland's Avatar
Rick Fahland
Default Replaced battery, remote start no longer works
After replacing the battery in my girlfriend's 09 journey everything works just fine except the remote start.
usually, your press the start button twice on the fob, the horn honks twice, doors lock, and the car starts up.. Okay. well now no matter how many times I press the button the horn honks only once and the doors lock, just as if I'd hit the lock button, it's like the darn thing forgot it's programming or something.
we have no warranty on the vehicle so any ideas, short of an expensive trip to the dealership, would be greatly appreciated. Thanks.
Old Dec 16, 2016 | 09:52 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You might have set some codes during the swap. If you ARE getting the honk when pressing buttons, then then at least one of the inhibit items is active. Check your HOOD switch first.
Remote Start Shut Down/Deactivate Conditions
Engine will NOT start or will shut down/deactivate during any of the following conditions:
  • Key in Ignition.
  • Doors or hood are opened before remote unlock.
  • Hazard Switch depressed.
  • Panic or theft alarm active.
  • Brake applied.
  • A prior remote start cranked the engine , but failed to start the engine.
  • Battery voltage NOT in the normal range. 11-15 volts
  • High (run away) or Low Idle (stall) RPM.
  • MIL Active.
  • High Engine Coolant Temperature.
  • Low Engine Oil Pressure.
Old Dec 16, 2016 | 02:01 PM
bigtsr's Avatar
bigtsr
On MY 2011 and up if you have low fuel level
the remote start will not work as well.
Old Dec 16, 2016 | 02:05 PM
TNtech's Avatar
TNtech
Under 1/4 tank I believe?
