Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
body control module
Old Sep 28, 2018 | 07:24 PM
marcus defey's Avatar
marcus defey
Default body control module
Anybody know where the body control module is locaed on a 2014 journey sxt 3.6?
Old Sep 28, 2018 | 11:34 PM
primem's Avatar
primem
behind the glove box, pivot the fuse panel down
Old Sep 29, 2018 | 09:26 AM
marcus defey
Thanks, will check it out. Need to change it and then have dealer program it. Driver door only, lock problem.
Old Sep 29, 2018 | 02:34 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I would be looking at wiring in the jamb of the door before I would dive into a BCM.
Old Sep 29, 2018 | 02:43 PM
marcus defey
Ya, the first thing I checked. Found a thread that noted this particular problem-only driver door locks and all unlock button works is related to a problem in the BCM-. Im with you though-always look for the cheap and easy fixes first.
Old Nov 1, 2018 | 06:29 PM
marcus defey
Had BCM swapped out and programmed and locks work fine now.
Old Feb 8, 2019 | 11:05 AM
Handyma dave's Avatar
Handyma dave
Default 2010 dodge journey 2.0 crd rt
Is the body control module in same place on mine.. is it behind glove box?
Old Feb 8, 2019 | 11:53 AM
TNtech's Avatar
TNtech
No BCM on a 2010.
Old Feb 8, 2019 | 12:11 PM
Handyma dave
Default No bcm??
Then what controls all the electronics?
reverse camera stopped working but flickers when operating rear wiper
operate rear wiper and interior lights come on for a bit
with front wiper on rear wiper wont work
when side lights and dipped lights on, interior lights come on
driver powerseat only goes up and down not back and forward
with lights on reverse lights also on but very dim
had all wiring tested and was told it was a faulty bcm
Old Feb 8, 2019 | 01:02 PM
TNtech's Avatar
TNtech
reverse camera stopped working but flickers when operating rear wiper.
All electronics are not dedicated to the BCM even if you did have a dedicated one like newer models.
Camera is controlled by the radio head
Interior lights are controlled by the cluster
Wipers are controlled by TIPM under the hood
Seat positions are controlled by the master switch on seat.
Reverse lights are controlled by the TIPM as well as Headlamps
What each module causes to happen depends on inputs that signal it to do so.
