Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2010 Journey not blend door actuator
Old Sep 10, 2019 | 02:51 PM
comsax1's Avatar
comsax1
Default 2010 Journey not blend door actuator
A few months ago, my lower A/C Heater vents along with the temp. blend quit working. I bought a new Dorman actuator and replaced the mopar. I also did a hard reset. Didn't work. In testing by plugging the power in first one , then the other, I learned that they functioned exactly the same. The problem is that neither one stops at the place where the lower vent opens. Could this be a control head problem? Any help would be much appreciated. Please help!
Thanks
Ross
Old Sep 10, 2019 | 10:18 PM
primem's Avatar
primem
if you remove the actuator...can you move the blend door by hand to the position the lower vent opens...if not the problem is in the hvac case.
Old Sep 11, 2019 | 10:08 AM
comsax1's Avatar
comsax1
Thanks,but if I move the control head from upper to defrost, I can feel the air come out of the lower vent for a second as it moves past the place that is supposed to stop.
Old Sep 19, 2019 | 12:38 PM
comsax1's Avatar
comsax1
bump bump
Old Sep 21, 2019 | 02:11 PM
comsax1's Avatar
comsax1
Default Question
Originally Posted by comsax1
bump bump
Is it possible that the aux actuator controls the blend and the air direction?
Old Oct 11, 2019 | 06:18 PM
comsax1's Avatar
comsax1
Please someone, My journey has only 2 actuators, I replaced the main one, but the temperature blend still does not work, and the air will no go to the floor duct. Please help
