Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
09 journey fuel pump run with key on?
Old Feb 20, 2021 | 12:21 PM
Johnpelchat's Avatar
Johnpelchat
Default 09 journey fuel pump run with key on?
09 journey 3.5 keeps loosing fuel pressure when sits but runs good. Took the injectors out and hooked fuel line back up to see if injectors were bleeding out but noticed every time i turn the key to on the fuel pump doesnt turn on it only does some times or all the time while cranking..
Anyway injectors were dry.
My problem is some times it will crank for up to 5 sec before it will start and some times itll start right up..
Would this be the fuel pump or could it be some thing else?
