Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Transmission temp
Old May 19, 2021 | 10:23 PM
hhjh444's Avatar
hhjh444
Default Transmission temp
After stopping at my storage unit today I noticed I only had 2nd gear fallowed by the check engine light and then I was checking the the temps and saw this.
Old May 20, 2021 | 07:39 AM
Get the code read fro the CEL. We can only guess what the issue is until you do.
Old May 20, 2021 | 08:26 AM
hhjh444's Avatar
hhjh444
Code p1745 was the only one and the live data showed no pressure issues.
Old Aug 6, 2022 | 12:11 PM
nathanblass's Avatar
nathanblass
Default Same issue
Did you ever get this figured out? I’m having the exact same issue with my 2013 Journey.
Old Aug 6, 2022 | 01:23 PM
Stan1037's Avatar
Stan1037
first thing to check is fluid level ....not sure what make or model but on my avengers the transmission cooler was in the condensor for the a/c unit ... make sure both fans are on ,,,,might be as simple as a fan relay
