Oil pressure problem
Hello
I have journey 2017 . The problem is with the oil pressure sensor when its cable connect to the fuse box the car delays to start up then i get many errors on the computer like the Tpim problem And all sensors stop If i disconnect it and put the cable that is from fuse box to the ground everything works fine And the computer give me only one error regarding the oil pressure sensor Can u tell me how i can find the shortage ? I already change the engine wire cable, throttle body and i get same problem I think there is a problem in body cable and i want to check where is it
Thanks.
Thanks.
