Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Vibration on Steering wheel and chassis.
Old Jul 9, 2024 | 12:42 AM
Kiril87's Avatar
Kiril87
Default Vibration on Steering wheel and chassis.
Hi lads,
I'm trying to fix vibration on the steering wheel and chassis from 4 months .
​​​​​​The vibrations appear between 115km to 127-135km and I can feel them more when I release the gas pedal.
However the vibrations are strong enough during acceleration also.
There was a small impact in aft RH wheel (you can see attached photo) but everything in the rear suspension has been replaced including the shock absorber with new parts
All mentioned below parts are new as well:
All brake rotors plus servicing of the calipers.
Rear RH and front LH wheel hub/bearing
Rear RH drive shaft
All front suspension control arm bushings
Drive shaft center support bearing
Drive shaft balance perform
Drive shaft rear coupler.
The vibrations are more when I drive with the 19" wheel but they are present with the 17" as well.
