2014 Journey 2.4L coils and brake rotors
Good morning,
For context, I have a 2014 Journey SXT with the 2.4L inline 4. This is super low budget model.
Hopefully someone can tell me what the proper ignition coils are for this 4 banger. Who makes the OEM coils for Dodge? What are good alternatives to OEM coils?
Also, what size rotors do I need for front brakes? I have seen 330mm and 302mm. I haven't taken a wheel off to measure them, hoping for an answer prior to doing that.
Thanks, y'all.
Thanks, y'all.
Is there something wrong with the coils? Those generally don't need to be replaced as a regular maintenance item unless they are causing problems. Stick with OEM or equivalent. As far as rotors go, you will need to take your VIN to a parts store and they can match with that/
I don't know. there is no CEL. But this thing DOES NOT accelerate. Nothing. It has a little oompf from a stop but as soon as it hits second gear, it just really doesn't do anything. It very slowly increases speed and the RPM climbs very, very slowly. So I'm just starting the exploration process of figuring it out. Besides, coils aren't that expensive.
