Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
traction control light on
Old Mar 2, 2025 | 01:48 PM
cvanfoss's Avatar
cvanfoss
Default traction control light on
ABS, Brake, Traction control lights on. scanner showing code c2200-49 internal electronic failure. Replaced ABS control module, ABS and brake lights are out. Traction control light still on. The traction control switch will not turn on or off the traction control light. Scanner can't initialize the mismatch for the abs control module to the vehicle because the esp is showing a satus as off on the scan tool. It is showing a code C006a56. Does this a possible bad esp module?
