Just put in a new Pioneer in-dash dvd
Had some issues here and there. The 2004 Durango dash kit from Scosche (crutchfield) does work. It took a very minor amount of modification( a little filing down on the inside edge). The 2002+ chrysler/Dodge harness works, with a few minor problems. The factory radio doesn't use a 12 volt switched connection. I got 12 volt sitched from the ashtray power socket. It's a 12 volt-10amp source which should be great for any aftermarket radio. The dimmer, cellular mute, and remote on/off wires are not used in the factory harness either. You need an antena adapter, the factory antena is an odd little plug. It's a standard Dodge adapter. Hope my trials and 3 hours of time invested (for a job which should have taken me 45 minutes tops) helps everyone else when their time comes to swap out the factory stereo.
