stock wheels question
Old May 31, 2007 | 11:53 PM
redline26's Avatar
redline26
Default stock wheels question
Hi Im a newbie. I just got a 2006 magnum that had 20" zinik wheels on it and I had to give them back. I put the stock wheels on. The problem is I dont have the right lug Nuts to fit the stock hub caps. Does anyone know where I could get a set of cheap lug nuts that will work with my hub caps . Thanks
Old Jun 9, 2007 | 04:25 AM
capnhook77's Avatar
capnhook77
Default RE: stock wheels question
i got my lug nuts at les schwab, but that's where i bought my tires though. Ask you a question? When you got your wheels, did they put metal air nozzles on? They put rubber on mine and I had to go back because they leaked and had them replace them with metal. They told me there's been a lot of problems with '20 rims leaking at the air nozzle.
Old Jun 9, 2007 | 04:29 AM
65standard's Avatar
65standard
i have tire pressure sensor valve stems in my '06 magnum. i have to use them instead of rubber or metal valve stems otherwise the tire pressure alarm and chime will go off.
