No ESP MOD the easy and cheap way
Old Oct 20, 2007 | 01:28 AM
nyinstaller's Avatar
nyinstaller
Default No ESP MOD the easy and cheap way
The no esp mod is easier than you think and does not need to be purchased from noesp.com
IF this thread helps you reply with a thanks or whatever
THe no esp mod works like this.
when pressing the esp button the mod counts a few secs before it activates a relay to seperate a wire connected to the shifter.
if you want to do it but cant afford the 50 bucks it will take you a few minutes and some simple things ( farely cheap and available at all car audio spots)
1 relay 12 volt5 pole spdt
1 toggle switch any kind
some wire and connectors
some directions.
thats it no esp mod not needed.
directions
take off the plastic bezel around shifter and find the violet ( with light blue strip) not dark blue strip (wrong wire)
remove radio and ash tray trim as well
take this wire and cut it with engine off. and extend it far enough to reach behind the cig lighter and ash tray
take one of the twoextended wires and connect it to pin 30 of relay
connect the other one to pin 87a of relay
connect pin 86 to the possitive wire from cig lighter wires. there is only two dont remember colors but i think youcan determine by color which one is pos ( better yet test this wire with ign on.
pin 85 connect to one of the poles of the toggle switch
connect other pole of toggle switch to ground
pin 87 not used
what this does is the same thing as the no esp .,
it disables the esp/bas feature of the car.
when the switch is on the relay seperates the wire and when the switch is off the relay is inactive and allows the wire to function properly. either way the ignition has to be one for the relay to work
to reenable the system simple make sure the switch is off and restart your car turning the ignition all the way off. than back on and restart. the only way to re enable the system shutting switch off will not work alone.
i found the empty spots on my sxt next to the ash try serve as a good spot for my switch which is black and barley noticed
the system will always be disabled if you keep the switch in the on possion wether you restart or not.
the difference between this and the no esp is two things.
one PRICE!!!!!
two the no esp uses a factory switch as this mod does not and you need to add a switch so you choose if using a factory switch is worth 50 bucks
check out the mod at www.NOESP.COM
than you decide cheap same results added switch or 50 bucks and using factory switch
Old Nov 1, 2007 | 12:23 PM
Angry Pickle's Avatar
Angry Pickle
Default RE: No ESP MOD the easy and cheap way
Ok, so I have to ask. What do they mean when they say it is only partially disabled with the on/off button on the dash? What part remains on?
