P295 rear tires
Old Oct 24, 2007 | 01:24 PM
MaDd0g's Avatar
MaDd0g
Default P295 rear tires
Has anyone put P295 tires on the rear of their magnum? What rims and tires did you use? Everything I have read shows a 20x10 wheel in the rear and a 20x9 in the front.
Old Oct 25, 2007 | 12:25 PM
Strykker's Avatar
Strykker
Default RE: P295 rear tires
295 is pushing it, without the right offset wheel(which will pull the tire inward towards the frame) you will run into rubbing problems.
If you are running tires that wide you will need to reduce the sidewall height significantly to keep it even lose to stock rotation and tire height.
My preference is a 275/40/20 which is plenty wide and no rubbing issues.
