Help with code
Old Dec 3, 2007 | 02:48 PM
bossman284's Avatar
bossman284
Default Help with code
I've been getting an intermintent check engine light. It will come on, and then within two or three strarts go away. Sometimes it's days or weeks before I see another one. Took it to the shop and here is what was discovered:
P0158 Bank 2 Senseor 2 Voltage Stuck High
Went with the obvious and easiest and replaced the oxyegen sensor hoping it was just a bad sensor...
A day later the check engine light was on again, and then 2 starts later it was gone.
If it's not a bad sensor anyone have an idea what would make it draw that kind of voltage.
Thanks in advance,
Bill[/align][/align]
Old Dec 8, 2007 | 12:56 PM
46FD04's Avatar
46FD04
Default RE: Help with code
Same problem here - a 2007 SXT with 3.5L engine.
Was a computer problem. They erased the memory, reflashed it, and all is well so far, for 2 days now.
Old Mar 28, 2008 | 10:54 PM
tmcnall's Avatar
tmcnall
Same here with the P0158 after replacing the sensor - mine is an '05 sxt 3.5L
Is the flasing the fix?
