MDS Sensor, What is it???
Old Jan 18, 2008 | 03:15 PM
laszloregos's Avatar
laszloregos
Default MDS Sensor, What is it???
I wrote in a recent post about my 07 Magnum R/T being stuck at the dealer since before Christmas. This is due to an MDS sensor that is leaking engine oil and which cannot be replaced because all such sensors are back ordered. According to the dealer he checked all other dealers in US and Canada, no one has them! Has anyone had a similar problem? I don't even know where these sensors are located on the engine. The MDS was working OK, despite the leak. I haven't been very forcefull with the dealer (or Dodge) because I have other cars to drive, and I'm out of town for a while anyway. I am starting to get concerned now because I will want the car back as soon as I get home, and they still haven't received the replacement sensors!
Old Jan 18, 2008 | 07:00 PM
65standard's Avatar
65standard
Default RE: MDS Sensor, What is it???
you are talking about the MDS solenoids.they are located under the intake manifold. there are four of them.
Old Jan 18, 2008 | 08:02 PM
65standard's Avatar
65standard
here is what the MDS solenoids look like. you can see one is broken.
here they are mounted under the intake manifold (valley area)
here are the plugs used to eliminate the MDS solenoids.
Old Jan 20, 2008 | 09:10 AM
evilhearseR/T's Avatar
evilhearseR/T
65...at what point in your series of mods, did you have to get rid of MDS? I know I will have to do it somehwere along the line, but not exactly sure when...
Old Jan 20, 2008 | 10:55 AM
Parts/Service's Avatar
Parts/Service
I just checked the availability of the multiple displacement solenoid, part # 50502152AC and they are not on back order. If I ordered them, I would have them the next day. I bet the guy ordering them cannot find them on the blueprint. They are listed with the camshafts. There are 193 dealers with these in stock...
Old Jan 20, 2008 | 11:34 AM
65standard's Avatar
65standard
ORIGINAL: evilhearseR/T
it seems that the MDS lifters can only handle a maximum lift of .529, with a .525 as the safe max. my cam has a .565 lift. i had to eliminate the MDS lifters and MDS solenoids and get a custom PCM flash to remove the program from the tune.
Old Jan 20, 2008 | 01:31 PM
evilhearseR/T
cool, thanks.
