Clock from 300C
Old Dec 21, 2004 | 07:56 AM
FordFanatic's Avatar
FordFanatic
Default Clock from 300C
Does anyone know if the center console trim with the clock from the 300C will fit in the Magnum?
Old Dec 22, 2004 | 05:04 PM
RcBandit28's Avatar
RcBandit28
Default RE: Clock from 300C
I don't believe it will stock......but who knows if you could modify it in anyway to make it fit.
Old Dec 23, 2004 | 12:52 PM
shiltz's Avatar
shiltz
the only issue I could see with swaping the trim pannel is you may need to swap the ac/heat ducting behind it too to match up with the heat vents from the 300 as they are different shaped.
