awd to 2wd
Old Mar 4, 2008 | 07:50 PM
carlosd1968's Avatar
carlosd1968
Default awd to 2wd
i have an awd magnum. i was wondering if i pulled the drive shaft out of the front will it then be 2wd? just like a 4wd truck our cars have a transfercase. i did not see any sensors at the case. i only see sensors at the wheels. has anyone tried this. i appreciate the help.
Old Mar 4, 2008 | 08:01 PM
65standard's Avatar
65standard
Default RE: awd to 2wd
it doesn't work like that. it is all wheel drive, not 4 wheel drive. the awd transfers 60% power to the rear and 40% power to the front. there are driveshaft speed sensor and wheels speed sensors. if the computer doesn't see sensor A + sensor B = preset C, it will go into limp mode. you won't make it two blocks.
Old Mar 5, 2008 | 08:05 AM
carlosd1968
i wasnt sure. thx for the follow up.
Old Mar 5, 2008 | 09:15 PM
65standard's Avatar
65standard
any reason why you would want to remove the front driveshaft (if you could that is)?
Old Jun 19, 2008 | 10:09 PM
06magnum's Avatar
06magnum
Junior Member
I personally love the awd. although i wonder what the difference would be like with 100% going to the rear.
Old Jul 7, 2008 | 10:31 PM
smithbro's Avatar
smithbro
I hate to beat a dead horse, but if these AWD systems are computer monitored, do you think a software adjustment would work to swing the ratios or "turn off" the system? In these days of high fuel prices, I am looking for MPG improvement.
