How do YOU shift?
Old Feb 20, 2005 | 04:22 PM
joemagnum's Avatar
joemagnum
Default RE: How do YOU shift?
I hope it is not slipping, it feels more like a computer glitch, actually now that I think of it, it feels like it bounces off the redline rev limiter, but it is only 5300-5400rpm when it does it..
Old Feb 25, 2005 | 02:26 AM
MikeEast's Avatar
MikeEast
Try this - after it's warm, in park, floor the gas and hold it there - hear that? Sounds a lot like the pause between shifts does, only lower rpm.
The computer won't let it over-rev, you are hitting the rev-limiter at around 3K or so in park.
I've noticed that easing back just a tad will let it gather it's wits and get the next gear going a bit better.
Also, if you haven't calibrated your gas pedal yet, give that a try as well.
Mike
Old Feb 25, 2005 | 11:00 AM
joemagnum's Avatar
joemagnum
"Also, if you haven't calibrated your gas pedal yet, give that a try as well."
How do you do that?
Old Feb 25, 2005 | 04:04 PM
MattRobertson's Avatar
MattRobertson
Joe,
I wrote up the procedure here:
http://foohbar.com/magnum_throttle_reset.cfm
Old Feb 26, 2005 | 01:24 PM
joemagnum's Avatar
joemagnum
I am not sure what it does, but something is defenitely different, and better! I missed the part about turning off the key quickly after flipping the pedal back up, but it sure seemed to work!
Thanks!
