Wheel Offset
Old Apr 27, 2008 | 01:22 PM
tropez67's Avatar
tropez67
Default Wheel Offset
I have been tring to locate a way to mount a new set of rims and tires on my 2005 Magnum for a while now, and haven't had any luck finding a way to. I need at least 1/2" spacer to keep the wheel from rubbing, the problem with that is the studs aren't long enough then.
The rims I have are 5x120 bolt pattern and fit the car, but the offset is off and I'd rather not have to sell them as I like the look.
Does anyone have any suggestions or ideas of how I can make it work?
Thanks!
Old Apr 27, 2008 | 07:57 PM
65standard's Avatar
65standard
Default RE: Wheel Offset
the correct bolt pattern is 5 X 115. i have 20 x 8.5 rims with a 20mm offset.
Old May 2, 2008 | 06:47 PM
Strykker's Avatar
Strykker
IMO, If you need a spacer that large that wheel is not for you. Magnums ride the best with wheels that do not require spacers. I personally don't take "make it work" approach to wheels they are your link to the road. Give it some thought bite the bullet and get the correct wheel specs.
