egr valve/sensor replacement?
Old Jun 16, 2008 | 12:02 PM
dbennett's Avatar
dbennett
Default egr valve/sensor replacement?
According to my check engine light code i need to replace my EGR valve/sensor. I remember seeing somewhere that you have to take off the intake to get to it. Is this true and if so is there a pattern to removing the bolts of the intake and to reinstall them. lbs of torque needed on the intake bolts. Is there another way to get to it? Thanks to all that reply.it a 06 magnum with AWD 3.5 V6 if this info is needed....
