HELP, radio static on hot days
Old Jul 10, 2008 | 10:56 AM
phil334's Avatar
phil334
Default HELP, radio static on hot days
2005 dodge magnum in callifornia. it is not consistant but on some hot days, 100 degrees or more, the radio works fine in the mornings but as the day gets hotter it develops more and more static until it is all static and you get no stations on am or fm. the cd still works ok. it never acts up on cooler days. the dealer says he has no idea what can be wrong with it, as usual.. someone told me the car has a "antenna booster" in one of the side panels but i have no idea.. i sort of thought the antenna in the rear glass but i would think if there were a break in a wire there it would be worse when it was cold.. any ideas ?????? thanks in advance
