Technical Description of Dual Plug Ignition
What do you want to know....it's like having built MSD ignition. Instead of having 1 flame front, you have 2. Doesn't help power much, more for smooth running and emissions, it makes the engine run very efficient.
ORIGINAL: dodgemech
So it is cross wired 1/6, 2/3, 4/7, 5/8
It appears that when #1 fires at say 32 degrees BTDC then #6 also fires at 32 degrees BTDC of the exhaust stroke. Apparently to improve emmisions. Is this correct?
That is what I also believe is happening. The second plug is fireing on the second stroke to burn off any unused fuel to help with emitions. Does nothing for performance. Did see some articals where people were trying to get both plugs to fire at the same time. I don't know if this would give any more power.
My thoughts are that it would be simple to rewire the coils to fire both plugs on the same cylinder at the same time. All it would take is about a 4 " wire. Unplug the cross fire cylinder and hook that coil connection to the second plug.
people have been doing that on the hemi rams, from the dyno tests it was basicaly no hp or torque increase, though suposedly the engine idles a little better after doing it, don't know if it will make it fail emissions tests though, the 5.7 hemi crate motor actualy comes like that I belive, also I think the 6.1 hemi may be like that as well, there are no spark plug wires running over the top of the intake manifold like the 5.7, unless they used longer cables and ran them around the back side of the engine.
