EGR evap sensor low voltage ?????????????
Old Jan 19, 2009 | 05:05 PM
dante0's Avatar
dante0
Red face EGR evap sensor low voltage ?????????????
Hi i own a Dodge Magnum2005 2.7L and a get a chech engin light , i have scanned the code and its P1400 (EGR evap sensor low voltage) i have replaced the Egr sensor with a new and reset the code ,but only after driving or 5 min its on again ,i have no vakum leaks, so a took the cables of and mesure the 2 cables and a have good ground and 12v+ on the other cable ,but if a plug it in the egr sensor the voltage disapers when a mesure it ,i have ground but no voltage ,,if a plugg it out a have 12v+ on the cable ???
Should it bee like that ?
What voltage should it have and were does it come from
Please ?????
Old Jan 19, 2009 | 07:19 PM
65standard's Avatar
65standard
did you change the EGR solenoid on the cylinder head or the EVAP sensor on the firewall?
Old Jan 20, 2009 | 12:56 AM
dante0's Avatar
dante0
hi i changed the evap sensor
Old Jan 20, 2009 | 08:49 PM
65standard's Avatar
65standard
a lot of time the evap code is from a loose or bad gas cap. also check to two vacuum lines from the evap sensor and make sure there are no leaks
Old Jan 21, 2009 | 04:47 PM
dante0's Avatar
dante0
Unhappy
Hi i tried a new gas cap but the code came back in 1 mile , when a suck in the hose that goes to the gastank a cant suck vacum is that right?? i have checked the 2 wires that goes to the evap sensor and the 2 cabels goes to the pcm ,and the cables is good!
Whats the problem???????????
Old Jan 21, 2009 | 04:54 PM
dante0's Avatar
dante0
And when a try to blow in the hose that goes to the gastank a can blow forever and it sounds like some air is coming out some were under the car ,is that right???
Old Jan 21, 2009 | 06:08 PM
65standard's Avatar
65standard
i would check the lines vent lines that run along the floor boards back to the tanks. i believe there is also a purge valve by the charcole canister. i will have to look at the complete evap system to see what else could go wrong.
